belt really needed?
Old Oct 16, 2003 | 03:13 AM
limige's Avatar
belt really needed?
i broke my alt. bracket and have to take it to the welder.
i was thinking the belt runs what,
alt
power steering
ac.
air pump
i am missing anything? since the water pump is driven off the timing chain and so is the opti couldn't i just drive it up there with no belt or alternator?
also, at the track couldn't you pull the belt and charge the batt. between runs?
thanks,
mike
Old Oct 16, 2003 | 03:20 AM
QCKZ28's Avatar
no the belt isnt needed as long as you have good charge on your battery, and yes some ppl do pull the belt for track runs. how long is the drive?
jesse
Old Oct 16, 2003 | 03:35 AM
limige's Avatar
not too far, at the farthest maybe 5 miles but i could probably find one closer, no biggy, i can through an extra batt. in the back as well, i'm all wired up for it for my stereo...
Old Oct 16, 2003 | 07:42 AM
No need to worry about the AIR pump, it is electric.
Old Oct 16, 2003 | 02:36 PM
limige's Avatar
then what is the pulley located next to the alternator, the backside of the belt wraps around? it looked like it had hoses going in and out of it like a small AIR pump. but i didn't trace them at all.
Old Oct 16, 2003 | 02:50 PM
That is the power steering pump toward the engine side. The AIR pump is located on the front of the engine, below the drivers side head, and is electrically driven.
Old Oct 17, 2003 | 10:59 AM
TQdrivenws6's Avatar
5 miles should be no problem, just lay off the electrical accessories. Try not to drive when you need your headlights, as those can take the juice out of a battery very quickly.
Chris
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
