what happens when you unplug the IAC? Idle goes down or up??
Old Oct 16, 2003 | 07:38 PM
LT1RX7's Avatar
I'm having a problem with my idle at 2000rpm and need to turn it down quick. I have the LT1edit but my laptop is at the college with my sister. Would unplugging the IAC turn the idle down?
Old Oct 16, 2003 | 08:06 PM
ead94z28's Avatar
I believe when you unplug the IAC the pindle stays in the same position and you will not see any idle change.
Old Oct 16, 2003 | 08:30 PM
ny_z28man's Avatar
I've never done it, but I would believe it depends on what postition it was at when you disconnected it.
Old Oct 16, 2003 | 08:47 PM
NOMAD's Avatar
Cool
Idle will shoot up. You might want to check and see if your throttle shaft or blades is binding, or check for a vaccum leak.
-Shannon
Old Oct 16, 2003 | 10:08 PM
ead94z28's Avatar
Here read this:
http://web.camaross.com/forums/showt...ght=unplug+iac
Double aught
Oct 2, 2015 11:29 PM
jayblev95
Sep 26, 2015 09:44 PM
95craz28
11
Sep 12, 2015 07:47 AM
damnyankee36
Sep 9, 2015 07:06 PM
tdigger9899
Sep 7, 2015 10:56 AM
