Low RPM stumble?
Old Dec 1, 2003 | 11:28 PM
ead94z28's Avatar
Low RPM stumble?
At idle I still have a slight stumble. Here is what is new:
Opti
Plugs
Wires
EGR
MAF
MAP
PCV
IAC
TPS
IAT
O2's
CAT
Coil
Starter
Any ideas what else I can look at. Stumble existed b/4 everything was replaced and is still there. Acceleration is great. No hard starting. No miss at high RPM's. TB was also cleaned as well. No codes and I scanned it with Freescan and everything looked fine. Stumble got better with pcmforless tune, but it is still there.
Old Dec 2, 2003 | 12:20 PM
ead94z28's Avatar
anyone?
Old Dec 2, 2003 | 12:35 PM
kindaslo's Avatar
No ideas here. I have the same problem though. On semi-fast acceleration of the pedal (not the car) it will stumble and backfire. At all other times it is fine.
I have a few datamaster logs, showing very split blms at idle and part throttle. They max at 160 when ever it stumbles too, so this leads me to believe that it is overfueling under hard throttle tip in.
I'm going to start wiht replacing 02 sensors.
Old Dec 2, 2003 | 12:38 PM
Rival's Avatar
my car is an m6 but I have a short pause when I try to get on it coming out of first. I have clean and checked everything too. They only way I have beaten it is to dump the cluth. Describe what happens as you go along. That may help others figure out your problem. I would try a f body only place and see what they tell you.
Old Dec 2, 2003 | 09:36 PM
$hawn's Avatar
fuel filter maybe? Check the fuel pressure.
Navecm
Jun 1, 2015 05:57 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
