How Hard And Long Will And Engine Swap Take!!
Old Dec 1, 2003 | 10:28 PM
97ramairtransam's Avatar
i have a 95 ta with 170,000 miles it blew a head gasket so im just gonna buy a low milegage lt1 and put in it can someone give me tips or a websight on the best way to pull the motor from the top or bottom? how high does it need to be to do it from the bottom? i will be doing this in a basment so ceiling height isnt very much!! just wanna know what the easeist way will be
Old Dec 1, 2003 | 10:46 PM
S.J.S.'s Avatar
you could do it either way but I don't see how you could do it in a basement. For one If you do it from the bottom you will need to get it at least 4 to 5 feet in the air. Ion (Madwolf) got some good pics. If you do it from the top you will need a hoist that will go up at least 6 feet. How high is the ceiling in the basement????
I just rebuilt my motor. To remove and tear down, took 2 days. To rebuild and drop in 3. So minus the teardown and rebuild. I would say you could do it comfortably in 4 days.
Old Dec 1, 2003 | 11:11 PM
97Camaro007's Avatar
Why don't you just replace the head gaskets....much easier to fix than the whole motor.....just a thought
Old Dec 2, 2003 | 02:54 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
I agree, unless you broke a piston, it's much easier to just replace the head gasket. Way too much time involed in swaping in a new motor. I've pulled about five, it's not fun.
rocketman051894
Jan 30, 2015 03:23 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 12, 2014 10:51 PM
