Peak Global Extended Life Coolant?
Old Dec 4, 2003 | 11:24 AM
Dave Holland's Avatar
Has anyone used this stuff or heard anything about it? System currently has Dex-cool. Plan on flushing and filling the cooling system. Since I'm flushing the system I'm not too concerned about compatibility, but it's supposed to be compatible with any type of coolant. Can't seem to find any info about it on the web other than on Peak's own site. Good stuff or garbage?
-Dave
Old Dec 4, 2003 | 11:36 AM
moparman's Avatar
Peak is good stuff. Go ahead and use it.
Old Dec 4, 2003 | 11:54 AM
WOT's Avatar
WOT
It meets Dexcool specs-it should be fine. Pep Boys carries it.
Old Dec 4, 2003 | 11:55 AM
ATMINF's Avatar
I would still just flush the system every two years and it should be good. With the extended stuff its okay, because it gives you some leaway on how long you "need" to change the stuff out. With my experence on my motor, when I rebuilt it it had 114,000 miles on it and had 7 years on it, the motor had NO rust or crap in the water jackets. All the freeze plugs(after I pull them out)looked new and no rust or "scaling" was in the block. So in my case old REDLINE water wetter, and 50/50 mix of distilled water and "orange" dexicool worked and still works great for me. Good Luck!
blac94Z
Feb 15, 2021 09:43 PM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
ducttape1975
Jul 10, 2015 06:29 PM
