1994 lt1 vats question
Old Dec 3, 2003 | 12:35 AM
elec87's Avatar
Thanks for looking guys. I have a question. lets say the wrong key is put into the ignition and the vats is not disabled, What exactly does it cut out. Will it kill the fuel pump, the injectors or the ignition. I am in the middle or retrofitting on into my truck and wired up the whole system and wanted to check to see if it would turn on. So far it all turned on and I tested the pin at the ecm for the fuel pump relay control and it showed a 12 source with the ignition on. I then check the injectors for voltage. I had not voltage on any of the positive power feed lines nor did I have a 12 volt source to the ignition module.. Thanks for anyput. Thanks for your time.
Elec
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Jan 4, 2015 11:15 AM
Fedesna
Nov 23, 2014 11:06 AM
Camaro90RS
Jul 23, 2002 07:57 AM
