Whats wrong?????
Old Dec 2, 2003 | 04:13 PM
White_96_Z28's Avatar
Exclamation Whats wrong?????
Ok today when I got home from school my mom wanted me to move my car so she could get hers out of the garage, and when i was about to start to move into the garage i had my car in neutral and had the clutch in and the radio was on, I hear this werid noise and turn off the raido. When i push in on the cluth with it in neutral it sounds like it is grinding.. whats wrong with it????
Old Dec 2, 2003 | 04:31 PM
ibanez6rg's Avatar
Throw-out bearing maybe.
Old Dec 2, 2003 | 04:32 PM
97WS6SCharged's Avatar
Do you have a stock or aftermaket clutch in the car? Also, is it hard to select gears with the clutch pushed in all the way?
Old Dec 2, 2003 | 05:49 PM
Im not sure, but I think its the stock clutch. No its fine shifting, but i found out tonight that it does it when it hasnt been started for a while. I had to pick something up and when I first started it and until the engine warmed up it was doing the grinding and then once the engine wamered up it stoped. Does that mean anything?
Old Dec 2, 2003 | 06:32 PM
Probably just clutch chatter. Check your master cylinder and make sure it's not leaking/low on fluid. Also, it may be getting time for a new clutch.
Old Dec 2, 2003 | 07:17 PM
if its time to get a new clutch what type do you suggest?
Old Dec 3, 2003 | 04:30 PM
Im taking my car in on Monday. Ill let you all know what was the problem.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
