Air Bag light is on all the time.
Old Dec 3, 2003 | 07:05 PM
JONEZ_Z's Avatar
Ever since I did my rebuild, my air bag light is always illuminated. It drives me nuts. I had pretty much everything apart but im pretty sure i plugged everthing back in. What are some possiblities that could be causing this? Thanks.
Old Dec 3, 2003 | 07:38 PM
WhiteBeast's Avatar
Check the 2 connections inside of the cab. One is behind the glove compartment door and one is under the steering wheel. They are both yellow connections.
This was the problem with mine, and it happened when i was transporting my car. Must of just came loose.
Good luck
Old Dec 3, 2003 | 07:55 PM
Yeah, an open connection is often the problem.
Old Dec 4, 2003 | 07:08 AM
JONEZ_Z's Avatar
Thanks alot guys. Ill check it out an get back with ya.
Old Jul 29, 2004 | 11:40 AM
SilverFormula's Avatar
Re: Air Bag light is on all the time.
Good luck
How do you get to these 2 sensors? do you have to remove the glove box? and do you have to remove anything ffrom the steering column to view the connections?
thanks
'95 a4 formula
Old Jul 29, 2004 | 11:47 AM
madwolf's Avatar
If you disconnected the steering shaft during the rebuild and moved the steering wheel, you could have broken the SIR coil which would cause the light.
dale3in98
Feb 14, 2015 12:18 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
