How much Lift can LT4hotcam springs handle??
Originally posted by 94 CAMRO Z28
Everything I have heard is you dont want to run them on anything producing more than .525 of lift. That is exactly what the Hotcam itself is with 1.6RR.
Aaron
Aaron
Rich Krause
Originally posted by rskrause
Coil bind is 1.22". So if installed at 1.800" .525" sounds about right. In addition, they are a fairly weak spring. About 100psi on the seat and a rate of 330lb/in. I wouldn't use them with any kind of an aggressive cam.
carguyshu
Jan 22, 2017 11:19 AM
