Driverside door lock problem
Old Dec 1, 2003 | 08:23 PM
gnxman87's Avatar
I just got a 1996 Z-28 and it had a Viper alarm system set up on it with remote start. The remote also has lock and unlock buttons on it which also arm and disarm the alarm. The locking/unlocking functions as normal on the passenger side but does nothing on the driver side. The lock buttons on either side of the inside of the car open the passenger door normally, but do nothing to the driver side as well. Since the driver side button works im assuming its not a fuse or wiring, but does anyone know what it might be? Thanks a lot.
Old Dec 1, 2003 | 09:10 PM
NewbieWar's Avatar
ive got a similar question im not exactly sure what u just said...
but my driverside door lock doesnt work. its feels like its not connected to the switch it will just bounce back and forth without any pressure or spring to it... the passenger one works fine, and the door lock manual switch works fine, and also the keyless entry works fine, so i imagine its just the switch is not connected to the button... how would i fix this?
Old Dec 1, 2003 | 11:29 PM
Spinner's Avatar
Buy a new switch
Old Dec 2, 2003 | 07:31 AM
gnxman87's Avatar
Yeah it's really difficult to verbalize this problem. The lock on the drivr's side is unaffected by any switch (be it either door or the aftermarket keyless), though the passenger side works. The switch that is on the driver's door opens the passenger side, but does nothing for the driver's side. What part do I need and is it easy to install?
Old Dec 2, 2003 | 07:50 AM
Based on the wiring diagram, I would say it is more likely the actuator in the door. Both L and R actuators are wired together after the LH switch, so if only one of them is not working, then it looks like trouble in the wiring or actuator.
Old Dec 2, 2003 | 12:37 PM
JasonL's Avatar
I'm going to have to vote for the actuator (motor) as well. The wiring diagram posted shows a typical GM "reversing polarity" door lock circuit. Generally this means *both* switches need to be functional, or neither actuator will work.
Get in there with a multimeter if you have one, and check the voltages going to the driver's side actuator. You will have your answer pretty quickly. Good luck.
Old Dec 2, 2003 | 06:36 PM
gnxman87's Avatar
Yeah both switches are working so I'm confident that it is the actuator. Ill have to change that when I replace the plastic piece on the door and the front speaker. Is the actuator replacement just a plug and play deal? Should it just get screwed in, plugged in, and be ready to go? Thanks a bunch.
Old Dec 2, 2003 | 07:17 PM
The Helms says to remove the rods and the lock assy from the door to replace the actuator. Install new actuator when the lock assy is open and don't let anything bite you.
Victor Lamb
Aug 26, 2017 02:52 PM
mattstrike
Mar 11, 2015 07:33 PM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
