Distributor
Old Dec 2, 2003 | 05:52 PM
BES-383's Avatar
Distributor
Has any one switched over to running a distibutor on their fourth gen. lt1?
Old Dec 2, 2003 | 06:16 PM
97WS6SCharged's Avatar
It can be done... but why? The opti is much more accurate for all it's woes. Plus, have you looked at where a distributor would sit? Not fun if you have to take it out. Also, you'll need some way to get a low res signal if you still want to run the car in sequential mode, otherwise it'll have to be run in batch fire mode.
Old Dec 2, 2003 | 07:03 PM
BES-383's Avatar
Am tired of messing with opti. Using accel gen7, so I will not have a problem running in sequential mode. Was thinking about using a PRO-BILLET FRONT DRIVE DISTRIBUTOR, it is belt driven.
Old Dec 3, 2003 | 01:36 PM
Or.... you could use the optical signals from your Opti to feed crank and cam position to your Gen 7, add an eDIS and run 8 LS1 coils in direct fire mode, and run your system in full sequential. Might outperform a mechanical distributor. An aftermarket ECU generaly gives you total control over fuel and ignition. By going to a mechanical distributor, you are throwing away 1/2 of the capabilities of the Gen 7.
8 LS1 coils in direct fire, using Opti + MoTeC
Just a thought.
Old Dec 3, 2003 | 01:40 PM
jonaddis84's Avatar
blah blah blah blah blaaaaah bla bla.....Thats all my brain heard when I was reading Freds post, that stuff is way over my head.....just one question....is this a very worth while conversion over the opti performance wise, or is it just something cool to get rid of the opti? And Im guessing it is an expensive conversion as well huh? Thats all I want to know. Thanks.
68camaroboltz
Oct 5, 2015 01:46 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
autoxr166
Sep 25, 2015 04:21 PM
1995Blackz28
Jul 20, 2015 09:34 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
