Quick Fuel gage/ Pump question - tie wraps?
Old Dec 1, 2003 | 09:29 PM
F Carline 94's Avatar
The fuel gage sender I got from GM didn't have the little metal bracket to hold the "curved tube" at the top. The one that doesn't exit the tank. I feel pretty solid that the other pump hoses are holding it in place, but does anyone see a problem with a tie wrap to hold it?
Will a common plastic tie wrap be a problem in a fuel tank?
Thanks Sean
Old Dec 2, 2003 | 06:29 AM
SWINGRRR's Avatar
What about one of those little clamp things that tighten as you turn a screw. I can find a pic if it would help. You can get them A-zone for about 50 cents.
Old Dec 2, 2003 | 06:48 AM
RamAir95TA's Avatar
Re: Quick Fuel gage/ Pump question - tie wraps?
Thanks Sean
I wouldn't trust it. I don't know the characteristic properties and how nylon reacts in a gasoline medium, but I would consider using something metal. Tie wraps are good for holding wires, not for restraining fuel tank components. It might work, but if it doesn't, is it worth dropping the tank again (or going through the hatch)?
I would find a clamp of some sort, or another sure-fire way to prevent it from falling off.
D1SC383LT4
Jan 1, 2016 01:56 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
