Headlight Bulb Size
Old Dec 2, 2003 | 06:18 PM
SiDeWaYZz28's Avatar
Headlight Bulb Size
hey whats up everybody what are the sizes for the stock low beams and high beams . . thanks
Old Dec 2, 2003 | 06:36 PM
AsianSensation's Avatar
H-6545
Old Dec 2, 2003 | 07:27 PM
EbeZ28's Avatar
I just swapped the stock halogen (out of the sealed unit) and used Sylvania Silver Stars. 9006ST for the lowbeams and 9005ST for the highbeams. They're SWEET.
Old Dec 2, 2003 | 08:08 PM
hey ebe how was the installation??did the lights plug right in??did you have to make any modificaions??thanks for the help!!!!
Old Dec 2, 2003 | 08:44 PM
timmyZ28's Avatar
I changed my low beams with Sylvania Halogens and the installation took me about 5 minutes.
Old Dec 2, 2003 | 10:53 PM
EbeZ28's Avatar
First off...I used the walkthrough located at http://performanceworks1.com/headlightmod.htm
I did all four lights in about 2-3 hours (I put one light in backwards and had to reset it). Basically the "sealed" beam is a 9006 series bulb with a non-standard mounting bracket held in with RTV sealant. I wiggled the bulbs free with a screw driver (careful not to pry to hard). Once the wiggled a bit, I twisted the bulbs like a bottle top and they popped off. Other than that I followed the instructions on the site above pretty much verbatum. I used ultra copper RTV to glue the new bulbs into the housing. Be sure get some on the inner rim of the housing so you have gooey stuff on both sides. The 9006 and 9005 fit perfectly. No modifcations to the housing or the bulbs were required.
Ahhh, about my screw up...the bulbs must be inserted into the housing in the same manner as the one removed. For example, if you take the stock low beam assembly out and look at it from the "top" (hood side) you'll notice that the wiring connector opens to the left. The Highbeams open to the right. The assembly will not fit back in its mount if you put the bulb in with the opening going the wrong direction. This is why I had to redo one of mine.
Oh and use lots of tape if you plan to install the housings without letting them sit for 24 hours. The tension from the wiring harness is enought to "unseal" the bulbs if they have not had a chance to setup well.
Also, another board member found a modified housing http://web.camaross.com/forums/showt...hreadid=198566 that might interest you as well.
Enough babbling for now
Old Dec 2, 2003 | 11:50 PM
thanks for the info exacley what i was looking for have you had any problems with water build up in the lights?
Old Dec 2, 2003 | 11:51 PM
Spinner's Avatar
I also did the same thing, with that same instruction page. No water build up, AWESOME lights. Cost me $20 a piece for each light. Took an hour or two to get it all done. Definetly worth it
EDIT: I couldnt pop mine out, so I used a heat gun on 700 degrees to loosen the glue. It got rubbery and the old ones popped right out
Old Dec 2, 2003 | 11:57 PM
EbeZ28's Avatar
No problems with H20 at all.
Henson071
Sep 18, 2015 04:01 PM
RobFlag
Aug 29, 2015 11:40 PM
RX Speed Works
Aug 20, 2015 03:40 PM
Dams76
Aug 20, 2015 08:28 AM
Aug 17, 2015 09:50 AM
