60 ft times
Old Dec 3, 2003 | 10:07 PM
97silverTA's Avatar
60 ft times
I have a 97 lt1 TransAm M6 and ran a 14.8 at the track. My 60 ft time was a horrible 2.53. How much could I lower my 1/4 mile time if I got a better 60 ft time? Thanks for your input.
Old Dec 3, 2003 | 10:10 PM
jonaddis84's Avatar
Bone Stock? If so you could hit a 14 flat or maybe a 13.8 if your lucky. Takes some good driving though.
Old Dec 3, 2003 | 10:15 PM
97silverTA's Avatar
I have CAI, Flowmasters, and an underdrive pulley.
Old Dec 3, 2003 | 10:17 PM
jonaddis84's Avatar
To clear up you have "flowmaster," only one on these, its not a mustang. And with that you should easily be able to hit 13.8 if you can drive it to 13.8. With an M6 its all in the driving.
Old Dec 3, 2003 | 10:24 PM
97silverz28's Avatar
Yoour 60's are bad. You should be able to hit 14 flat with driving, if you can hook up.
Old Dec 3, 2003 | 10:35 PM
QCKZ28's Avatar
what tranny do you have?
what was your mph?
Old Dec 3, 2003 | 10:50 PM
97silverTA's Avatar
I have a T-56 and my MPH is almost 97
Old Dec 3, 2003 | 11:35 PM
RickS's Avatar
what RPM are you shifting at?
anyone have sugestions?
5900-6000 is what i got my best times with
how in tune is your lt1?
Old Dec 3, 2003 | 11:53 PM
QCKZ28's Avatar
what kinda of tires are you running?
get a set of DR and you can easily pull a 1.9 sixty foot, you would run 13.9 or so.....
i could not believe the difference with DR, they HELLA hook.....
i run them all the time now
jad
Old Dec 4, 2003 | 12:33 AM
97Camaro007's Avatar
With a 1.9 60' you might see some 13.7's......just my thought
Old Dec 4, 2003 | 12:39 AM
Rival's Avatar
I would tune you car up and then buy a pair of radials. Then smoke them up and dump the clutch. Not too hard. How long have you been driving stick for? Practice starting from a stop to wot. Try not to spin your tires and still floor it. You'll get it once you have sticky tires. It is easier. Your times will drop down to a high 13 with a 2.0 60ft. Good luck
QCKZ28's Avatar
quite possible, if i could lower my sixty foot to 1.65 i might have touched 11's
but i dont have a 12 bolt/et streets yet.....
just a thought
12.51 at 115.4mph with 2.06 sixty
jesse
Old Dec 4, 2003 | 02:14 AM
S.J.S.'s Avatar
Are you burning out a lot off the line?? That 60 is way off. Whats your elevation at your track??
Old Dec 4, 2003 | 10:53 AM
97silverTA's Avatar
I'm shifting at 5800. I just have normal street tires. the elevation at my track is very high, all cars normally run slower there. I can't even floor it until I get part rolling pretty good otherwise I just stay in the same place. the track here has horrible traction. I haven't been driving a stick for a long time.
Old Dec 4, 2003 | 03:48 PM
WS Sick's Avatar
Yes Amarillo is pretty high up there, If I remember right is close to 3000 ft. But at least its dry over there...he he.
No kidding lets just say that you drop to a 2.1 60 foot, its my experience that every tenth you remove from the 60 is close to a tenth and a half at the big end. so all thing constant you should easliy hit a 14.0 or 13.9 with decent traction.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
