Emissions "Frendly" cam Question
Old Dec 2, 2003 | 06:53 PM
NJCustoms's Avatar
Ok , I'm looking for a Emissions Friendly cam. It does not have to Be CARB legal but something i can work thru NJ Emissions. I have the LT-4 Converstion kit, but relize there are ALOT better cams out there that will make MORE POWER. THe car is a 6 speed 94. I have the Jet Hot LT, H pipe and Loudmouth. Input here guys.
This is my daily driver so, No Race cams. Suggestions? Mybe a sound clip or Movie Clip? Thanks All.
Old Dec 2, 2003 | 07:22 PM
NJCustoms's Avatar
Anyone????
Old Dec 2, 2003 | 07:29 PM
drewstealth's Avatar
cc305, 221/227xe, 224/230xe if on a 114 lsa. There are plenty out there those are just a few. If the cam is on a 114 lsa it is a lot better for emissions.
96z's Avatar
96z
The hotcam maybe as emissions legal as your going to get without tricks or some real good tuning.
Old Dec 2, 2003 | 07:40 PM
NJCustoms's Avatar
2. PowerMax Hydraulic Roller Camshafts for Computer Controlled Vehicles
Application Series & Grind Number
For 94-95 highly modified, aluminum head LT1 Camaros, Firebirds and Corvettes. High flow heads, headers and exhaust required. Manual trans recommended. Top end power with some low end loss. Use 10758-16 1/6 ratio rocker arms for more power. Not for use w/stock springs. For mass air F.I. only. (50 state legal for listed applications, C.A.R.B. E.O. D-225-55) Basic RPM 2800-6500 PowerMax
2050
Cam Specifications
Degrees Duration @ .050 Int./Exh. Degrees Advertised Duration Int./Exh. Degree Lobe Separation Open/Close @.050" Cam Lift Int./Exh. Lash Hot Int./Exh. Gross Lift Int./Exh.
218
218 280
280 116 (2) 40
50 (12) .000
.000 .498
.498
Old Dec 2, 2003 | 07:43 PM
DamianLT1's Avatar
Hotcam or CC305 anything higher you will probably need Dyno tuning.
Old Dec 2, 2003 | 07:50 PM
Is NJ harder on emissions then cali? Because people have passed in cali with the 221/227xe(not sure if 112lsa has worked) and the 224/230xe 114lsa with just mail order tunes.
Old Dec 2, 2003 | 08:22 PM
b-stevens's Avatar
On the xe221/227, what makes the lift numbers so much higher than the xe224/230? Or am i mistaken?
Old Dec 2, 2003 | 08:34 PM
stereomandan's Avatar
I asked that same question a while ago, but got no response. Why does the 221/227 have such a high lift, and what does it gain you?
Dan
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
Queens94z28
Nov 20, 2014 06:03 PM
