lt1 2 LT5
Old Dec 2, 2003 | 05:52 PM
1984camaroz28's Avatar
lt1 2 LT5
is it possible to do this swap... and what will i need
Old Dec 2, 2003 | 05:55 PM
ShelbyZ28's Avatar
The LT5 is a totally different engine. I believe it has dual overhead cams amoung many other differences. Not worth the trouble if its even possible. Maybe someone else can chime in who knows more about them
Old Dec 2, 2003 | 05:56 PM
drewstealth's Avatar
Well you can probably swap the whole engine. But they are totally different blocks. Not like the lt4. It would be very expensive though and not worth the cost. You could build a very nice 383 stroker for less money. This has been asked quite a few times before so if you do a search you can probably find out more info on this.
Old Dec 2, 2003 | 06:11 PM
HM Murdock's Avatar
Not only that, but the cost of rebuilding an LT5 is over 12K. Those Lotus designed Mercury Marine built DOHC 32v V8's are sweet, but damn expensive to work on. Heck, the starter is under the intake manifold in the V of the engine... It'd be cheaper and more reliable to do a heads, cam, and rebuild of the stock block...And you could be just as fast...
Old Dec 2, 2003 | 06:15 PM
Try a search. You are suggesting a very expensive project.
Old Dec 2, 2003 | 11:33 PM
yes just thought it whould be nice
Old Dec 2, 2003 | 11:59 PM
HM Murdock's Avatar
The other problem is if the massive heads would even fit. GM did a 3rd gen with the LT5, and it's a damned tight fit...
Old Dec 3, 2003 | 12:17 AM
AG's93Z's Avatar
http://www.zr1.net/
I'm sure you'll find alot or something here!
Old Dec 3, 2003 | 02:22 AM
HM Murdock's Avatar
Originally posted by aggiez28
well the answer to your question is yes.... it is possible.
brook
True, with money, anything is possible...
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Caps94ZODG
Aug 15, 2002 06:22 AM
