O2 sensors and MPT
Old Dec 3, 2003 | 01:52 PM
Blackfire's Avatar
O2 sensors and MPT
how can i tell if my O2 sensors are bad without getting a diagnostic, or scan...whichever it is. Im getting about 190 to the tank. I just picked up a fuel filter. And i just changed plugs and wires, opti is also good.
Old Dec 3, 2003 | 02:13 PM
95BlackTA's Avatar
I was interested in this too.....so I bought two new ones. I dont really know if there is a way, even with my scanmaster. I replaced one, but I broke the tool trying to get out the second. Im taking it to a shop tomorrow so they can bang on it with air tools.
Good luck ill let you know if mine helped. Also I get like 13.5 mpg per tank, and I smell gas....so hopefully this would be the culprit.
Old Dec 3, 2003 | 02:36 PM
turbo_Z's Avatar
replacing them every 50k miles is probably a good idea. unless there are visible signs of damage to the sensor or wiring... you cant "see" a bad one without diagnostic tools. as for judging a bad sensor with a scanner before actually getting DTC error codes would be to make sure the O2s function within thier entire 0-1000mv range. if you find one only ranging from 300-600mv for instance then its not working properly and need replaced.
Old Dec 3, 2003 | 02:59 PM
Blackfire's Avatar
i dont smell gas at all. but i do get about 13.5 mpg, which is a little tough being a poor college student
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
