Any tricks to bleeding/changing brake fluid?
Old Dec 3, 2003 | 07:06 AM
MILESF's Avatar
Question Any tricks to bleeding/changing brake fluid?
I just bought a MityVac vacuum brake bleeder so I can change the brake fluid by myself. Are there any tricks to doing the change? Do I have to worry about the ABS? How about the bleeder valve on the master cylinder?
Thanks,
Fred
Old Dec 3, 2003 | 10:06 AM
madwolf's Avatar
Those bleeder valves on the master cylinder are for bleeding the master cylinder itself.
I did this before and the way to do it is the following:
Rear right, rear left, front right, front left.
I just used the $3 autozone tool and a free friend to pump the brake pedal.
Mityvac rules!
Old Dec 3, 2003 | 05:01 PM
slopokrodrigez's Avatar
When you do, the ABS light will come on unless you shuttle the ABS motors according to the manual. The light went out on mine after about a day even though I did it like madwolf said (old fashioned way)
Let the fluid in the resevoir get real low before you add new fluid the first time so the old is flushed completely.
Old Dec 3, 2003 | 05:09 PM
WOT's Avatar
WOT
Bleeder screws on the MC? Are you sure you aren't talking about the bleeders on the ABS modulator? Mity Vacs work well-although if air leaks around the bleeder screw threads you'll need to apply a heavy grease to the outside to seal it.
Old Dec 3, 2003 | 07:27 PM
solid's Avatar
How would you bleed them if you wanted to just change the brake lines to steel braided ones?, wouldn't you have to take all the brake fluid out completely in order to change to new lines, and risk getting air into the entire system.
Old Dec 4, 2003 | 08:44 AM
WOT's Avatar
WOT
You just have to be quick and do one line at a time. Leave the cap on the MC to slow down leakage. You'll have to top it off ocasionally too if you're slow-a partner helps here. It also helps to put one thumb over the open line while you're manipulating the hose. You will leak brake fluid-but it won't drain out as fast as you think.
Old Dec 4, 2003 | 08:59 AM
MILESF's Avatar
Talking
Thanks for all the info. What company is a good source for the stainless braided lines? Seems like a good idea if I'm flushing the system.
Fred
Old Dec 4, 2003 | 09:22 AM
WOT's Avatar
WOT
I used Earl's. There was a nice difference between them and old rubber oem hoses. Russel also makes some but I don't think they have the 5th line nor is their quality on par with earl's. Jeg's has them for a reasonable price.
BinkZ28
Apr 20, 2015 09:10 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
captcorvette
Mar 7, 2015 12:37 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
