Installing Scanmaster on 97 SS w/ OBDI?!?!?
Old Dec 3, 2003 | 06:58 PM
Stealth Z's Avatar
Question Installing Scanmaster on 97 SS w/ OBDI?!?!?
I got a datamaster from my 94 Camaro that I successfully hooked up when I had that car. Now I have a 97 Camaro with a OBDI swap. . . I'm not sure which wires are which and don't have a manual for it. Which wire is the signal wire that I hook into for the information?
Old Dec 3, 2003 | 07:34 PM
ZLT195's Avatar
Are you hookin a datamaster or a Scanmaster?
Data wire. Connect to the "data" terminal in the ALDL connector. In the 94's this it the lower right hand pin. On all models, this is a light tan wire.
Depending on your connector its either pin 12 for a 12 pin ALDL or 9 for a 16 pin ALDL
Should be one of those.
Z~
Old Dec 3, 2003 | 07:37 PM
95 Silver TA's Avatar
Looks like Brent did this on his 96SS with an OBD1 PCM, Heres the link:
http://www.bfranker.badz28.com/fbody/scanmaster.htm
You should probably PM him if you have any detail questions.
Thx,
Claude
Old Dec 3, 2003 | 08:43 PM
Brent94Z's Avatar
Super Moderator
Yep, I did this The listed page above will show you exactly what to do. FYI, it doesn't matter if it has an OBDI or OBDII PCM... the wiring stays the same at the ALDL connector. In fact, I would sometimes switch back and forth between OBDI and OBDII PCMs (My OBDI PCM has been modified to accept an OBDII style 100k ohm knock sensor)
Nov 18, 2023 07:21 PM
Peytons'z
May 6, 2021 09:25 AM
aj2494
Mar 12, 2015 10:17 PM
thenewkid
Nov 29, 2014 04:54 PM
