any reason to replace water pump coupling?
Old Dec 2, 2003 | 02:52 AM
PatsTA's Avatar
I'm going to replace my water pump next week, wondering if there would be any reason to also replace the water pump coupling (connects the water pump to shaft coming out of timing cover). Can those things wear out (car has 120k)? I'm going to replace the o-rings for sure. Only reason I'm asking is the couplings are ~$35 on gmpartsdirect, seems kind of expensive.
Thanks,
Patrick
Old Dec 2, 2003 | 03:44 AM
96z's Avatar
96z
If it looks worn or that it may slip ofcourse replace it. If it is in good condition use it by all means.
Old Dec 2, 2003 | 05:18 AM
S.J.S.'s Avatar
Heoooo No!! I thought I lost mine when I was putting my motor back together, called the Stealership and they wanted a murderous 70 fricken bucks for that lil sonama biyatch. I didn't even ask if they were serious. I'm still thinking they musta made a mistake.
Old Dec 2, 2003 | 05:59 AM
Mtrhds94Z's Avatar
Only reason I can think of is if it's pitted at the seal surface area... or if you lose it..
I just use the bench grinder wire wheel and clean it up...
Old Dec 2, 2003 | 07:25 AM
You could clean it up an then put a dab of new grease on each of the splines before youre reassemble it.
SJS, I am sure they quoted you list price-no mistake. It is an expensive piece.
Old Dec 2, 2003 | 09:03 AM
S.J.S.'s Avatar
I wouldn't doubt it bro.... Still ridiculous as hell though for such a small ars piece.
Old Dec 2, 2003 | 01:26 PM
Chris 94Z A4's Avatar
I just replaced my water pump about two weeks ago. All I did was clean up the splines with some WD-40 and put it back in. I didn't bother to replace the o-ring on the cam drive shaft pin as the original one was stuck on. There wasn't any moisture in there, so I left it alone.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
