Nitrous UH-OH
Old Dec 3, 2003 | 07:37 AM
Sweetred95ta's Avatar
Nitrous UH-OH
I had this under another thread but thought that someone might be able to help me if I posted it differently. I sprayed on my ac delco platinums the other night and it melted the **** out of them. The car was running pretty bad, so I replaced them with NGK TR6's. Even though the new plugs made it run a little better, it is still missing through out the rpm range. And is running rich still. What else could I have done??? Please no hole in the piston. Please no hole in the piston. Please no hole .......
Benji
Old Dec 3, 2003 | 10:21 AM
I am going to do some compression testing, anything else I should do??
Benji
Old Dec 3, 2003 | 10:34 AM
Gripenfelter's Avatar
Check all the plug wires for burns.
Disconnect the MAF and see if it still misses.
Old Dec 3, 2003 | 10:37 AM
What will disconnecting the MAF tell me??
Benji
Old Dec 3, 2003 | 10:42 AM
Lost's Avatar
What exactly was the uh oh? A nitrous back fire through the intake perhaps? Or did you just have it jetted/hooked up wrong?
I think if you do a compression and leakdown test you'll know the health of your pistons and rings.. if they come back good then I'd say you're ok. Then just start checking for routine problems like wires arcing..
Old Dec 3, 2003 | 10:44 AM
The UH-OH was running platinum plugs while spraying 150 shot. The wires didnt look bad, and I cant ever get all of them not to arc (no matter how much dielectric grease i use). Even before the problem.
Benji
Old Dec 3, 2003 | 10:48 AM
A quickie check for broken rings lands - the most likely problem, if you actually damaged something - take the oil fill cap off and feel for "huffing" out the tube when the engine is idling.
Old Dec 3, 2003 | 11:56 AM
Red_94Formula's Avatar
Oh wow your doing a 150 shot with heads and cam! damm I gotta try that
Old Dec 3, 2003 | 01:54 PM
Just dont do what I did and you'll be fine.
Benji
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
