jet hots here, drivers side has only 3 bolt ups...
Old Dec 3, 2003 | 02:21 PM
glennxx1's Avatar
and then another pipe seperate, that should slip in to the missing bolt up,(where header bolts to heads)but when i stuck it in there it isnt any wehre near close to bolting up even with other pre-welded head to header bolts
Old Dec 3, 2003 | 02:29 PM
glennxx1's Avatar
well i was mistaken, it does kinda sorta line up, but question, do i have to weld them together?or just leave as is slip on?
Old Dec 3, 2003 | 02:51 PM
joeSS97's Avatar
It is a slip fit.Dont weld it unless absolutely necessary.I have ceramic coated Hookers(same thing)and the fit was real tight with no leaks.Some people do have trouble with it leaking.Hopefully you wont.
Old Dec 3, 2003 | 03:29 PM
Javier97Z28's Avatar
Moderator
It's slip fit... although sometimes I've seen it where there's too much coating on the end of the loose pipe and you may need to sand it down a bit for it to fit properly though. Don't worry, the tighter it gets the less chance of a leak. Do like I did and use some hi temp RTV to seal it off for good. Dont' weld it.
LT14LIFE
Feb 9, 2015 09:35 PM
ModdedNerd
Jan 29, 2015 07:23 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
