Plug Wire Heat Protectors
I used the cheap Spectre stuff from jegs. Put two layers on each wire. To test it i put a single layer on an old wire laid it on an exhaust manifold. Didn't damage the wire althout i'm sure my headers get hotter than that manifold did. I think you should route them so they don't touch and just use the insulation for 'insureance'.
-brent
-brent
I used the Taylor extreme ones from Summit, about $50. I think they were good up to 1200*'s. I wouldnt use them again. They are staright and fit like crap on the 90* boots. Also they are real big around and touch the headers on a couple of spots. The heat turned them white, they are orginally red.
I am going to hold out for an OVC kit later on in the new year. Hows the car coming?
I use Taylor heat sleeve. Not cheap ($10 each) but it works great. See pic.
http://www.97ta.com/misc_pic/misc32.jpg
Asian- What wires are those? MSD's?
I used those same boots on a set of Taylors and they run to close to the JetHot LT's. I think a zip tie on mine would cook off in no time being so close to the headers. The wires arent really long enough to effectively tie them up away from the headers.
As for the car, hopefully the wires and new plugs (old ones were FOULED) does the trick. It's the only thing I can think of at this point, because everything else checks out. Hopefully, with any luck, I'll be able to hit the dyno again and finish the tune and then swap the 1.7's in.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
grabbem88
Mar 18, 2015 01:25 PM
