ed timing chain
Old Dec 2, 2003 | 08:03 PM
besz28's Avatar
ed timing chain
hello i just bought an xe 230/236 112 cam. is this the timing set i can use with a 1994 z28?i still have a stock waterpump? gm parts direct has kit number 12370835 for like 202.00 dollars is this the one i need?
Old Dec 2, 2003 | 08:06 PM
AsianSensation's Avatar
You need to do a vented opti conversion if you want to use a LT4 ED timing set on a non vented opti car.
Old Dec 2, 2003 | 08:34 PM
madwolf's Avatar
Yep, a vented opti conversion is required for any chain stronger than stock.
I did a 233/239 just recently and went with a new stock timing chain and crank as well as cam gear. It should be OK although still has slack in it.
Lunati makes a chain for 92-94 LT1s (you can get it from summit I beleive) and looks like someone already tried it and is happy with it. A few weeks ago when I did the cam install, I just decided to go with the stock one. Didn't want to be the first one to try it....
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
