To manual shift or not to manual shift????
Got my A4 with the mods below and was wondering if I should maually shift it or not. I know when it was stock I didn't and it was consistent as hell and ran good. Not sure about now.
thanks.
thanks.
Originally posted by FastZinTennessee
When I'm at the track I leave it in first, just in case I spin bad and the car shifts itself, then when I get about halfway through first I put it in drive.
Excellent Idea, i just "assumed" it would not work.
Originally posted by Blue96z28
but i was wondering this exact thing, once i get going hard in 1st(@4000 or so) can i shift into D, and it still rev all the way outta 1st and 2nd to redline? If so then thats awsome.....
Yes you can. That's the point of an automatic transmission, it does all the work for you.
Definitely leave it in "D". Once in a while, if my car is in "OD", my car will not get off the line in 1st. When it's in "D" it will always start out in 1st. Even for my burnout "D" is awesome. Although FastZinTennessee brings up a good point that if you have problems with spinning the tires at the end of 1st, you won't want the tranny to shift to 2nd too early.
That is a very good point becuase I finally nailed her for the first time last night from a dead stop and it spun like mad and I could barely hear it shift. Did it quick. But hell...... I was moving at like 35 mph and stop it and it broke loose. These Dunlops suck.
I leave it in drive when I go to the track.
The only time I shift manually is when I want a good second gear scratch, I can leave it in first and then roll out a little stomp it and then shift into second, it gets good gear that way.
Originally posted by 97blueZ28
yeah but yall cant beat a goood 6spd remember +2 gears double overdrive luvit!!!!!
??? Get a good witness and a time slip. I'll race ya from here.
