No heat please help
Old Dec 3, 2003 | 10:35 AM
BC56F100's Avatar
No heat please help
Ok I have a 95 z and the heater does not work at all. I have gone completely through the motor and have all the bolt ons, hot cam w/ rockers shaved heads etc.. The heater lines go into the heater core but there isnt even warm air slightly blowing out the bottom vents like it usually should. I have had some buddies tell me that there is a switch in line with the heater hoses, but I havnt been able to find it. Can anyone please help me. This is my girlfriends car and I am getting griped at every second cause its getting cold now. Thanks
Billy
Old Dec 3, 2003 | 10:56 AM
There is no switch in the heater hoses. You probably have a clogged heater core. Flush it with a garden hose.
Old Dec 3, 2003 | 11:11 AM
BC56F100's Avatar
Just unhook the lines and flush it or would I need to remove the core? Thanks
Billy
Old Dec 3, 2003 | 11:32 AM
BC56F100's Avatar
Man shoebox you have an awsome site. I am going to meet my girl for lunch and program the keyless entry. Thanks alot man!!
Old Dec 3, 2003 | 11:39 AM
S.J.S.'s Avatar
Just unhook it and flush it. If it doesn't work you might need another core. It's like60 bucks or so and takes 20 minutes max to change out. Even someone with no mechanical experice can do it with a pair pliers and 5mm socket.
Old Dec 3, 2003 | 11:48 AM
BC56F100's Avatar
Sweet preciate it guys. I will let yall know if it fix's it. Thanks again.
Billy
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
