Welding stock rear end axles to pumpkin?
Old Dec 3, 2003 | 06:48 PM
Robert95z's Avatar
Anyone ever done this? If so did you weld on the top of the axle (hard to reach)... Just curious
-Robert
Old Dec 3, 2003 | 08:57 PM
Smokn '94 Z's Avatar
Lightbulb
You mean the Axle tubes to the Pumpkins right?
Old Dec 3, 2003 | 09:31 PM
Heatmaker's Avatar
Advanced Member
Yeah unless you want a 3000lb driveway orniment
Old Dec 3, 2003 | 09:51 PM
Robert95z's Avatar
Of course...
Old Dec 3, 2003 | 10:16 PM
Heatmaker's Avatar
Advanced Member
THe 12 bolts are built up that way. I don't see why the top would be hard to reach. Just unbolt the suspension and the rear should dropout and you should have pleny of room.
Old Dec 4, 2003 | 05:12 AM
slopokrodrigez's Avatar
What is it you're trying to accomplish?
Old Dec 4, 2003 | 09:22 AM
Robert95z's Avatar
strengthening the weak 10 bolt
Old Dec 4, 2003 | 09:29 AM
NOMAD's Avatar
Won't help in that case. Thats not the 10 bolts weakest point.
-Shannon
Old Dec 4, 2003 | 09:39 AM
BitCypher's Avatar
I'm no expert....but I'll throw my $.02 in the mix.
The only thing that's going to do is lessen the chance that the axle tube will flex at the pumpkin which does indeed strengthen the rear-end to a point. However, it would be more important to strengthen the internal parts by way of larger axle diameters and stronger gear material. I know what you're after because I'm in the same boat. Unfortunately, the crappy part is that the cost of building up a strong durable 10-bolt usually costs more $$$ and time (which is $$$) than just buying a 12-bolt or Ford 9" and being done with it (and done with worrying about the 10-bolt).
YMMV
Old Dec 4, 2003 | 10:27 AM
OutKast's Avatar
There's always the 8.8 swap
Old Dec 4, 2003 | 10:33 AM
Grease's Avatar
Yu don't really gain anything by welding the axle tubes to the differentials on our cars. We have torque arms which keep the pumpkin from rotating backwards. I doubt anyone has ever spun the diff on a 93 or newer f-body. Gears break long before that would ever happen.
Old Dec 4, 2003 | 10:34 AM
Robert95z's Avatar
Well I cant afford or even come close to affording a 12 bolt or a 9inch. Im just another 18 year old college student... Hell i can barely afford to put the rear end gears ive had in my room for a couple weeks. Been doing a a little reasearch and heard about welding the axle tubes to the pumpkin to strengthen it a bit. And since I have free access to a MIG i figured why not
-Robert
Old Dec 4, 2003 | 10:37 AM
And..... when you weld the tubes in-situ, how do you know that you have not heat warped and distorted the tubes to the extent that the axle housing assembly is no longer "straight"?
Old Dec 4, 2003 | 10:39 AM
Robert95z's Avatar
I was told to carefully weld 1/2in bead welds and let it cool after every bead, untill you have a full bead
Old Dec 4, 2003 | 10:44 AM
Robert95z's Avatar
Doesnt really seem like you guys are fans of this, so maybe i'll just leave it alone
