ABS INOP light on...where to start?
Old Dec 2, 2003 | 04:34 PM
WhiteBeast's Avatar
Ok, today my ABS INOP light came on and stayed on when i started my car. It is not flashing but I was just wondering where i should begin to search for the problem before taking it to my mechanic.
This morning when it stayed on, and my engine was running i went and pulled the fuse in the engine bay and put it back in and hered a click or something like that (couldnt really here it over the engine) and then checked and saw that the light was off.
Does this sound like a bad relay?
Old Dec 2, 2003 | 04:50 PM
nitropatch's Avatar
you should first start checking your sensore by the wheels if one is unpluged or damaged then the light will come on.
Old Dec 2, 2003 | 04:53 PM
Heatmaker's Avatar
Advanced Member
I had the ABS inop light on.
2 Scenarios
1. My rear Tail 3rd brake light wire came loose...that set it off.
2. My ABS/Brake sensor inside engine bay (near the ABS module) came out...that set it off also.
Usually it's an electrical problem when the ABS inop light comes on like that.
I've only seen the light come on "foreal" once...when I was sliding on ice and trying to brake.
Old Dec 2, 2003 | 05:51 PM
WhiteBeast's Avatar
OK, I checked all of the sensors and they look good. Couldnt actually see the back ones, where are they located?
Anyway, after guess and check i disconnected both ABS fuses and then when i put them back in i could here the relay kicking on and off. Then after putting the ABS ign fuse back in i heard one click and then both the brake light and ABS light turned off.
So it is deffinately electrical, and im pretty sure i have a bad relay.
I wonder though what could be making it click on and off?
Im not sure, any ideas?
Old Dec 2, 2003 | 06:20 PM
FastZinTennessee's Avatar
I think it's grounded on the crossbrace right behind where the lights are on the drivers side. Check that ground point. You can see the connection right on top.
Old Dec 2, 2003 | 07:04 PM
slopokrodrigez's Avatar
Scan it, every time the ABS light comes on a code is stored. Clear it and see if it returns. Then break out the shop manual.
Stop guessing.
Old Dec 2, 2003 | 07:08 PM
S.J.S.'s Avatar
Hey dude...surprised no one mentioned this but I just had that exact same problem and all it was was that one of my sprak plug wires were too close to it. Did a wire change lately???? I just moved the wire and the problem was gone. The wires affect the sensors if to close.
eazyZ
Mar 1, 2015 07:12 AM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
blac94Z
Dec 2, 2014 12:09 PM
