of these 2 cams, what would you pick
Old Dec 3, 2003 | 11:13 PM
93Z286Speed's Avatar
Of these 2 cams what one would you pick and why?
First Cam: Combination Motorsports custom grind
227/233 duration, .560"/.569", 111lsa (lift numbers with 1.6rrs)
Same cam on 1.5rrs would have this for lift 525/533
Second Cam: Comp Cams XE Grind
230 / 236, .510 / .520 112 LSA (Lift Numbers with 1.5rrs)
Same cam on 1.6rrs would have this for lift 544/555
Im doing heads and cam durring this winter and want to know what of these 2 cams you would pick, I dont wanna rev the **** outta my motor (thus why you dont see the bigger cc306 cam on this list) These 2 cams look like the better choices over the 306 and other cams
Any and all input welcome
TIA - Mike
Old Dec 3, 2003 | 11:18 PM
Got-LT1's Avatar
I'd say the top one
Old Dec 3, 2003 | 11:33 PM
QCKZ28's Avatar
check out my sig.....i will be going a little bigger cam this winter
jad
96z's Avatar
96z
The first one simply without going to into explaination.
Low duration
High Lift
Tight LSA
Old Dec 4, 2003 | 09:04 AM
Originally posted by 96z
The second one simply without going to into explaination.
Low duration
High Lift
tight LSA.
and why do you think thats better?
the first one has less duration and more lift with an even tigther LSA
Old Dec 4, 2003 | 10:04 AM
jkipp84's Avatar
That's what I was wondering.. Another vote for the 1st one.
Old Dec 4, 2003 | 11:16 AM
rskrause's Avatar
Moderator
Not enough info. RPM range desired? How is the car used? Gearing/transmission? What associated parts will be used? Displacement and static CR? Etc.
Rich Krause
Old Dec 4, 2003 | 11:36 AM
madwolf's Avatar
Mike,
don't you have to pass emissions? Or did you get around it?
Old Dec 4, 2003 | 11:42 AM
after talking with the people over at Combo motor sports ive decided on the first cam with 112 LSA to bring the RPM range down a little bit (stock bottom end) And ion i do have emissions, but ill worry about that when the time comes i think or find a relative that will register my car in a different town.
Car the cam is going in
93 Z28 6 Speed with 3.73 gears
RPM Range wanted is probly no more then 6200 RPM
Cam will have a SWEET custom tune (right ion? ) heh
CAI Headers catback all that fun stuff done
Will be running #30 lb accel injectors and probly a 58 mm TB
I think lloyd elliot is doing my heads because he seems to be way to cheap to pass up from what im finding, If the moneys there might go with bigger valves. probly 2.00 intake and 1.56 exhast
Will be using 1.6rrs with Comp R lifters and whatever springs and pushrods needed.
Old Dec 4, 2003 | 11:45 AM
got_hp?'s Avatar
i havent seen any one put down any numbers with the 227/233 yet............but we all know the 230//236 works great.
drptop70ss
Mar 26, 2015 01:50 AM
pimpss96
Feb 12, 2015 01:28 PM
95chwagon
Jan 13, 2015 09:19 PM
skittlez87
Dec 29, 2014 03:23 PM
siguy
Nov 27, 2014 10:07 AM
