View Full Version : LT1 Based Engine Tech
- Which philosophy do you go by?
- Another cam type questions? lol
- Chime in - who's had a new stock LT1 timing set fail?
- Higher idle than programmed.
- MAF/MAP Sensor Specs?
- spark retard question
- valvetrain noise
- do i need to shim 10308 kit with 224/224, .532/.532 cam
- Need Help Pickin a Cam
- lt4 and orgional lt1 wiring harness
- Tryin to get an idea
- Arr 210 Heads
- Please Help!!!!!!
- what rocker arms and springs to get
- oil pump/pick up tube?
- What would cause hte right bank short term fuel trims to go 190+?
- short simple
- Should I remove the LT1 and swap in a 406?
- idle problem after driving
- 1997 Lt1
- Right BLM's @ 160 on new motor...Lots of info inside.
- Symptoms of bad coolant temp. sensor?..
- Need LT1 Specialist in VA
- exhaust fumes inside
- BCM bypass module
- lt1 misses at 5500 rpm
- Pacesetter instsall question
- New lifters worth it??
- Finished replacing head gasket, car runs like crap
- Le3 Questions
- Anyone ever played with the baby Lt1, GM L99 motor?
- bearing cap tq ?
- Sparkplugs
- Valve cover question
- I just can't figure this out (Electrical)
- Gm Hi-Tech Article
- rod bearing ?
- anyone here have an aluminum flywheel?
- Getting ballancer off for UD pulley install
- i need some help.
- Rate my rebuild kit
- opti to intake elbow hose size
- Am i gonna wash my engine(injector size)
- Manual steering rack - ??
- delteq timing question
- OVC Passenger side wire routing...pics?
- Anybody have or can take pics of their '93's headers/egr system?
- [edit] could be making this rattle!
- Cam Sputter/Stall
- 3.73 gears :: speed discussion
- Is this bad to do?
- Where can I get a vented gas cap for deleting EVAP
- 160 thermostat
- OTVC wires
- Urgent Info Needed On Lt1
- Zero deck height + 306 cam = Problems?
- oil pan question
- oil pressure gage sticking.
- one more question
- Starter wont engage when key is turned
- Need some part #'s asap plz!!!
- quick question about water pump install..
- scoots good from a roll - not so from dead stop
- Air pump part number
- Camaro Newb Ignition Probs!
- How many ground point on the engine?
- New Radiator Fan Setup?
- Getting trouble codes p0335 and p0336
- my tl4 getting spanked by a buick
- Cooling System Flush Issues?
- Cam Swap??
- Cam Question.
- We have a problem, not sure what it is
- Balancer and Crank Hub?????
- 94 LT1 carbed into 79 K10
- throttle adjustment
- Quick question on water pump and opti install...
- Completely Stumped Please Help
- Any way to lower idle??
- DTC 16 and 36
- Engine pics
- Forged 355 LE2 head / LE1.5 cam LT1 done.
- Normal to puff some smoke with no cats??
- compression ratio change...
- no spark at coil or resolution signals
- I need urgent help ASAP!!!
- stroker q's
- stroker q's
- glowing exhaust
- cleaning oil pan
- Rebuilding the EVAP system?
- LE3 Heads, LE3.2 cam. Idle and <3000rpm problems
- ID that sensor
- Did I ruin my optispark?...
- Deleting power steering have questions>>
- When does a 52MM TB becme a restriction?
- Exhaust video clip.
- bad gas milege, o2's
- vacuum vs. fuel pressure
- roller rockers
- delteq Q's
- Car smokin' like a chimney... (VIDEO)
- Oil pressure drop at wot fixxed
- help with oilpan clearance
- Window Motor - Both sides?
- Kinda New...
- lt1 bad design?
- Oil Pressure Questions.
- air injector pump went out
- cooliong system
- Do ARP head bolts HAVE to be torqued before use?
- Underdrive pulley not good??
- What belt for March 2-pulley set
- 94/95 harness and computer differece?
- Sounds like a high rpm miss, doesn't feel like it...any guesses?
- Low Speed Stumble Gone
- So many opinions on cutout location which one do i pick?
- 1.6 Comp pro mag RR install questions
- I got 167 knock count and 160 for IAC
- ENGINE IN!!! Video clips of idle-XFI 292 cam
- car dying while driving
- 1994 Z28 specs
- 383 LE2... low numbers on the Dyno. Help!
- CAI+LT headers+ORY+catback+tune=???
- No start condition.
- best push-rods for my set-up?
- question on lt1 afr 190 heads
- odd fuel pump behavior
- what should I do next with a stock 94 z28
- intake gasket fix
- 400ci+ LT1 (yea I know again)
- Car stored for two years
- RPM and type of main caps
- pilot bearing install question
- random engine stalls when gassed, po118
- Ebay Optispark. Is it a real GM part?
- Engine dies at random and difficult to start once warm
- I'm in Los Angeles... Hlp Me out!??
- Delteq owner come inside(opti question)
- Not just another cooling question
- search=no hit..opti question
- plugs and/or wires?
- Someone put a banana in my tail pipe?
- Stock windage tray removal
- car feels gutless after converter swap
- head gasket choice
- How to replace oil pump spring?
- Stumble and ****....
- cc306 q's
- Plug Gap?
- what is this? (pics inside)
- Miss Fire On #7 With New Injector
- MAC slip on pipe....how did you guys get it on?
- part # for oil filter
- Car is overheating...
- Weird Fan Problem
- buying a used cam?
- how to change oil drive gear
- Werid issue - one side of engine reads really lean and goes too rich
- Sparks w/ Hooker Headers
- Vortec rotating assembly in LT1
- Timing Lights & MSD CDI Ignition
- Will a thrown EGR code cause the fans to stay on?
- highway fast
- Camaro newb Needs help! Coil Probs i think
- Cars Running......With Issues Help Please
- Are there any redeeming values to a Hypertech tune?
- Spark plug wires and passenger side opti....
- Header EGR hookup...might not be perfect
- low compression 383 intended for boost, supercharger must wait
- Brand new motor and RATTLING What is it???
- LT1's on E85.
- Summit Throttle Body?
- Lets talk about 1 piece seal cranks?
- please help, how dose this motor sound
- water temp. gauge?
- cooling fan question
- Huge Problem....motor mount mounting holes stripped
- help on o2 sensors
- Missing coolant; constant draining of battery...need help
- New Jegs oil pump with pictures
- I thought I narrowed down the problem?
- Intake Elbow
- A/C Firewall Stuff, removal
- bad vibration
- New 355 vids
- what keepers and shims to use with these springs and retainers
- how high with forged interals
- are front and rear o2's the same?
- installing rail mount fuel pres gauge, need thread sealant?
- Knock on the shifts
- Checked fuel pressure, opinions on results.
- Shoebox: I need your input please!
- Quitting on its self
- parts list for 93 thru 02 camaros lt1, ls1 all v6's
- Uh oh.. one more time
- Help - Rod Rust (Need OpinionS)
- B body maf hurt performance?
- deleted rear 02
- Sparks jumping to my water pump and ASP balancer/pulley. WTH.
- closed loop
- random question
- Who's got the FASTEST...
- Engine Dies While Driving
- Delteq hookup question
- Borg-Warner Opti?
- Bosh injectors
- Locate o2 wires
- TB gasket set part# needed
- Dissembling Heads, Valves Don't want to Drop out...need HELP
- Motor Almost Ready To Start
- SES codes without the red light?
- Maf Screen
- 94/95 headers on a 93?
- stock tb size?
- lt1 in 69 camaro
- How do I install the Cam trigger?
- Headers HP and TQ gains
- What do guideplates do?
- 1,000 to spend... What to do?!
- Dynomax X flow
- Canton oil pan users inside please...
- timing cover
- what belt to use after AC delet?
- 58mm tb gasket?
- pcv and fresh air setup questions
- Pulsation
- what would i benefit
- what is causing this pop/backfire?
- Enough is enough! New opti, ICM, Coil, and opti harness still dies and cuts out
- SES Light Blinking
- ? about roller rockers
- I cant find the wire that goes to the temp sensor in the head
- Stock Shortblock-how much power?
- built forged 396 ,internal or external balanced?
- Oil Pressure 0 PSI @ braking
- tune out o2 sensors
- Piston ring thickness?
- Question about a stock coil
- Normal O2 sensor behavior at startup..Are mine shot?
- before cat o2's
- Another Motor Almost Complete!!
- Car won't start .. crap crap crap
- head gasket : felpro 1094 : LT1 ??
- What would you do?
- Timing chain off a tooth?
- Header install begins tomorrow
- Voodoo Cam???
- What do you guys think of this 355 LT1 Setup?
- opinion for LE2+hotcam+58TB+32
