Enough is enough! New opti, ICM, Coil, and opti harness still dies and cuts out
OK, I put in a new opti, harness, coil, ICM, coil wire, & Plugs. The car ran fine for a few days after I put the new opti harness on. Then after taking it up through the RPM's it started to run like crap again. Now it will start and run but after it gets warmed up everytime you let off of the gas it dies. Plus it cuts out real bad after 4000 RPM?? What the helll is wrong with this thing? Do you think that an LTCC kit would fix my troubles?
Thanks in advance
Thanks in advance
My car missfires a lot but after I put pulf wires it took care of it, now I put a coil, it runs good but not were it should be, I think that a Fuel system service, clean the throttle, intake, and fuel rail, will take of the problem and improve throttle response also. I will be use BG chemicals.
Dylan Latshaw
Mar 21, 2015 09:48 AM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
