how to change oil drive gear
Old May 10, 2007 | 12:02 PM
jeepbeast's Avatar
just wondering how the he** do i change this oil drive gear? i've been staring at this thing and have no clue.
trying to bolt this thing up tonight. any help would be greatly appreciated guys...
thanks
Old May 10, 2007 | 12:31 PM
bingo's Avatar
Are you referring to the drive in the back of the block that allows the oil pump to be driven by the camshaft?
Old May 10, 2007 | 12:49 PM
jeepbeast's Avatar
yes..do i push that hollow dowel out towards the bottom?
Old May 10, 2007 | 12:55 PM
bingo's Avatar
The drive itself is fastened with a bolt in the lifter valley. If you are replacing the entire assembly, you would simply remove the bolt, remove the assembly and install the new one. If you are merely replacing the gear: remove the assembly, remove the small roll pin that retains the gear with a small punch and reinstall the new gear on the assembly. I had to replace the gear on my previous LT1. I bought a regular distributor gear for a 92 TPI engine to be sure the gear would be compatible with a roller cam.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
