Another cam type questions? lol
Old May 17, 2007 | 12:29 AM
95fbformula's Avatar
This is a custom cam for an H/C stock SB lt1 with supporting mods would it be to small for a 355 with a 3600 stall and 3.73s. I believe its power peaks at 6800 which is were i want it to.
234/248 .608/.576 110lsa
Old May 17, 2007 | 12:36 AM
seawolf06's Avatar
Definitely not too small for a 355. Where did you get the specs and the cam ground? Looks good and I don't see many cams with that duration and lift. What are the rest of the specs? (advertised duration, lobe lift, ICL, etc.)
Old May 17, 2007 | 12:43 AM
Its from the post with the TEA heads on a 96 m6. jason99ta posted it i believe. I am doing a similar build using the TEA stage 2 heads but on an auto 355 and that cam specs for it seems to work very well with there head set-up. making very good numbers on a stock Sb I was thinking of having something similar ground by TR but didn't want to encounter any unforeseen problems. I still have a lot of information to gather though.
Old May 17, 2007 | 12:55 AM
seawolf06's Avatar
Oh, ok. I love the way that car sounds and drives. It's a beast.
Old May 17, 2007 | 12:58 AM
Really? are there any sound clips of it i would love to here it.
Old May 17, 2007 | 12:39 PM
seawolf06's Avatar
Mine is very similar(see sig). It's a little different than hers since I have an open borla, but almost everything else is the same. Mine sounds better, of course.
JK, NAT!
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
