Valve cover question
Old May 15, 2007 | 07:12 PM
TACamaro's Avatar
I am about to put on a set of LT4 valve covers. I was wondering, do those need to be modified to fit over Harland Sharp 1.6 roller rockers? I know the stock ones needed to grinded and all kinds of stuff. Any mods need to be done to the LT4 covers?
Old May 18, 2007 | 04:17 PM
TACamaro's Avatar
anyone know...
Old May 19, 2007 | 01:23 PM
seawolf06's Avatar
They might or might not. Not many people are running these. They were supposed to be designed to fit with the GMPP 1.6 RR so there is more clearance there. I doubt they're any taller, though. You'll have to test fit them to be sure.
Old May 19, 2007 | 02:13 PM
Severous01's Avatar
the only reason stockers need to be clearanced is because they have tangs that connect the upper side to the lower side...and since the factory rockers dont use trunions, they have all the clearance they need. but when you throw huge trunion bearings on a rocker, clearance between the rockers is lost...and in some cases as little as 1/16" is all that's left...
so, you should have no problems with the composite covers since they dont have the tangs in them.
Old May 23, 2007 | 01:01 AM
SSTAT's Avatar
Where did you get the Lt4 covers?
Old May 23, 2007 | 10:52 PM
TACamaro's Avatar
I got them off ebay
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
