DTC 16 and 36
Old May 13, 2007 | 08:32 PM
TACamaro's Avatar
DTC 16 and 36
I got a quick question. My car quits running after it warms up. I replaced the ICM and it still dies, still only after it warms up. The only 2 codes I pulled were DTC 16 and 36. All the wiring metered good throughout the entire ignition system. I metered terminal "B" on the ICM connector and got between 1.9 - 2.1 volts AC while the car was running. When the car started to stumble and die, it still the read the same, 1.9 - 2.1 volts. My MSD box and coil checked good and fuel pressure seems normal. I think its the opti, but want to make sure. Another thing, when the car starts to die, the tac goes crazy. Looks like a bad signal coming from the opti. Any suggestions.
Thanks,
Kiel
Old May 13, 2007 | 09:11 PM
my94blackz's Avatar
If it does it does this, http://s35.photobucket.com/albums/d1...=Crazyness.flv replace the opti.
Old May 13, 2007 | 09:31 PM
TACamaro's Avatar
Watching that video was just like driving my car...lol...I kinda figured it was the opti ****tin on me...thanks.
Old May 14, 2007 | 05:33 AM
Guest47904's Avatar
Guest
Did you pull the 4 pin connector plugged into the distributor? Seen many a person here have corrosion on the connector to which a new opti won't fix the problem.
Old May 14, 2007 | 03:57 PM
TACamaro's Avatar
Yea...I checked out all the wiring and connectors in the whole system...everything checked out good.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
