help on o2 sensors
Old May 9, 2007 | 05:19 PM
Sporty-X's Avatar
help on o2 sensors
Just wondering :
i had an o2 sensor (front) that have died during the year. As i wasn't using anymore the rear ones, i just took one and put it instead the front one that was dead. Since that, i'm using my car without any problem ...
I've just seen a post telling the sensors are not the same at front and rear ? Is there a problem running sensors as I'm doing ? should i have to change sensors ?
Old May 9, 2007 | 06:37 PM
How did you do that? The rear ones have different connectors to keep them from being interchanged.
Old May 10, 2007 | 06:00 PM
Sporty-X's Avatar
i have to extend wires when i installed my Pace Setter LT so .... i just cutted the wires from the rear sensors as i've done on the front ones and put them instead.
Am I in trouble running like this ??? (even if happy with my 320 Rwhp) or should i buy new sensors ?
Old May 12, 2007 | 05:50 AM
Guest47904's Avatar
Guest
It's never a good idea to cut and splice the O2 wires. There should always be untouched wire from the O2 to its connector. What you do between the PCM and the connector realy doesn't matter. In fact it's not even recommended to put dielectric grease on the connector.
Old May 13, 2007 | 04:00 PM
Sporty-X's Avatar
hum .... i don't know how to go to the LT without any extension to the wire. I had also to route the wires different way do do so.
Anyway : are the front and rear sensors same except connectors ?
Old May 14, 2007 | 07:40 PM
Guest47904's Avatar
Guest
It doesn't matter what you do to the wires from the PCM to the connector. Just don't splice from the connector to the O2.
But you can get extensions from Summit or Jegs.
http://store.summitracing.com/egnsea...%2D109010&x=25
Old May 14, 2007 | 07:58 PM
They are different part numbers, but that may not be based on the connector alone. I don't know if there is a functional difference. You might be able to tell by doing a swap and comparison with a data logger.
Old May 16, 2007 | 12:34 AM
Sporty-X's Avatar
i'm running one front sensor and one rear sensor so.
When i get time, I will look with freescan if i have a différence on the sensors readings
Old May 16, 2007 | 01:38 AM
speed_demon24's Avatar
I don't think gm would make 2 different part #'s of 02's and make them use different connectors for no reason, chances are there is more of a difference than just the connectors.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
