best push-rods for my set-up?
Old May 11, 2007 | 07:05 PM
lt1rx798's Avatar
i figured out that i need 8." / .080 rods at 5/16th's width, but im looking for suggestions on the best rods for the job.
i know they are a little long for an lt1, but that is what they measured out at......lt4 heads with .100 longer valves. it is a solid roller motor that im expecting to turn up to around 72-7500 rpm's, and i also have jesel shaft mount rockers, and push-rod guides to be on the safe side.
what do you suggest?
Old May 11, 2007 | 07:17 PM
lt1rx798's Avatar
http://store.summitracing.com/partde...6&autoview=sku
any opinions on these?
Old May 11, 2007 | 08:50 PM
rskrause's Avatar
Moderator
I assume you will be using pretty stout srpings? I'd call Manton, but I think you need thick wall pushrods for added rigidity. Something in the .095 or more range.
Rich
Old May 11, 2007 | 10:20 PM
lt1rx798's Avatar
yeah, i think the seat pressure is around 210-215lbs.
...so i should use a thicker wall...?
Old May 12, 2007 | 02:07 AM
rskrause's Avatar
Moderator
Manton "Series 4" are $160.00/set and are better material with a little thicker wall (0.083"). If you are on a very tight budget, the Comps will be ok.
Rich
stangkilla1
3rd Gen / L98 Engine Tech
Feb 10, 2003 03:32 PM
94DROPTOPZ28
N2O Tech
Jan 27, 2003 11:56 PM
FilledWithFurySS
Dec 4, 2002 10:38 AM
DarthIROC
Sep 5, 2002 11:56 PM
jim88iroc305
Aug 13, 2002 09:24 PM
