water temp. gauge?
Old May 9, 2007 | 08:09 PM
DZNUTTS's Avatar
water temp. gauge?
Quick question. My stock water temperature gauge stopped working.
What should I be checking. I opened the radiator cap and I see coolant flowing.
Old May 9, 2007 | 08:32 PM
2000GTP's Avatar
What do you mean it stopped working? Are you referring to the gauge on the dash cluster? If so, that input is provided by a coolant temp sensor found in the drivers side head.
Old May 9, 2007 | 09:22 PM
DZNUTTS's Avatar
yes the one in the dash cluster.
where exactly is that sensor located on the drivers side head.
Old May 9, 2007 | 09:28 PM
FlamingChicken's Avatar
between #1 and #3 i believe. right under the header/manifold flange
Old May 9, 2007 | 09:30 PM
seawolf06's Avatar
Yes. Shoebox might have a way to test it on his site. www.shbox.com
You can always hook a scanner up to the pcm to make sure it's working.
Probably just came unplugged.
Old May 9, 2007 | 09:53 PM
JAB's Avatar
JAB
The sensor in the head between #1 and #3 only sends it's signal to the dash gauge. The temp sensor in the water pump is the one that the PCM uses.
Old May 9, 2007 | 10:03 PM
seawolf06's Avatar
I know, that's why I told him to test to make sure that the OTHER one was working. That's the really important one since it tells the fan when to turn on. The gauge really doesn't make any difference what it reads.
Old May 10, 2007 | 11:46 AM
2000GTP's Avatar
Here is the link to Shoebox's site for testing the water temp sensors: http://shbox.com/1/4th_gen_tech2.html#ect
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 23, 2015 08:50 AM
Biggiebound
Apr 21, 2015 11:28 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
brentbrowning01
Dec 16, 2014 06:35 AM
