Did I ruin my optispark?...
Old May 13, 2007 | 10:20 AM
CrazyLT1's Avatar
Hey guys,
Car was running like crap and finally died on me about 2 weeks ago - it had no spark at all. So I changed the optispark, and it then had all kinds of spark but would not start. It turned out that I installed the optispark wrong (not flush with the timing cover) -and that is why it wouldn't start.
Then, I re-installed the new optispark the correct way - and the car ran AMAZING for about 2 weeks. So I thought I was all set....
Now - the car is starting to show the same symptoms as it did before I changed the optispark in the first place (erratic idle, hesitation, etc.)
So I am wondering if I could have damaged the optispark by having it bolted down tight without being in the correct place and cranking the car over numerous times. My car is a 1997- so its the dowel pin set-up. I'm pretty sure that the 1st time I had the pin just into the butterfly indent and not in the hole. Because when I loosened it up to check it - the opti was pulling itself off of the timing cover as I loosened the bolts a little bit.
So do you think I may have damaged the opti during that process and it just took a couple weeks to start screwing up again? Cause I know your not supposed to put too much pressure on that wheel ( and I had it torqued down with just the pin pressing right on the butterfly). Or did I just get a bad opti?..... thanx in advance
Old May 13, 2007 | 12:15 PM
mrmint69's Avatar
I would double check all connections and see if it is something else first. I would think a visual inspection would tell if something is broke or out of place.
Old May 13, 2007 | 12:30 PM
94CamaroZ28's Avatar
Yes, you may have damaged it.
Old May 13, 2007 | 02:05 PM
CrazyLT1's Avatar
Ya thats what I figured, darn!!
I just thought it was wierd how it ran great for around 2 weeks and finally started screwing up now. Just got back from taking it for another ride - it just threw the service engine soon light on and its acting like it wants to die just like before.
Even though it was my pretty much my fault - this will be 3 optispark removals/replacements in 2 weeks. I'm getting just a bit frustrated....
Old May 13, 2007 | 02:09 PM
mdacton's Avatar
what codes do you have....could be something else
2000GTP's Avatar
On the bright side, you should be quite good at doing them now after 3 times.
Old May 13, 2007 | 05:57 PM
11secgen's Avatar
no, you didnt ruin the optispark.gm did!
Old May 13, 2007 | 06:01 PM
CamaroSS30thAnn's Avatar
i got a chuckle out of that
Old May 13, 2007 | 07:58 PM
quickSS's Avatar
You might have something else in the spark circuit going south. Possibly the coil is on it's way out. A bad coil will act somewhat like a bad opti.
I did the same mistake as you when installing an opti, (many moons ago). and that opti was not damaged thankfully. I would expect yours to be ok too.
Karl
Old May 13, 2007 | 08:30 PM
CrazyLT1's Avatar
Well, the coil is only a month old. So it shouldn't be that. That was one of the things I replaced when I first started having issues.
I just have a bad feeling that I ruined the new opti. Especially cause I think I may have torqued it down more than necessary the time it was on wrong.
Plus - the current symptoms just seem like a bad opti. It stumbles and hesitates - especially in the lower RPM's. It pops and backfires while driving. It goes from good idle to poor idle, etc. and tries to keep catching itself, etc....
Jeff1904
Jun 5, 2016 05:00 PM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
colts0455
Sep 27, 2015 01:07 PM
