opti to intake elbow hose size
Old May 15, 2007 | 07:29 AM
SkiBumDreams's Avatar
What is the size(diameter) of the hose that goes from the intake elbow (NOT into the ds of the intake) to the opti? Also where might be a good place to pick up a replacement, might a menards or lowes kinda place have the proper kind with a fitting to connect to the elbow? this is probably why i keep having ignition issues if my opti keeps sucking up moisture and such (i hope).
Old May 15, 2007 | 08:25 AM
Mike96z's Avatar
well just go down to autozone, pickup some vacuum hose + a set of those plastic elbow pieces and you will have it done in no time. Doesnt matter the size of the hose, as long as it can breathe.
Old May 15, 2007 | 09:53 AM
i just wasnt sure if there was more than one diameter cause it has to be a snug fit so it doesnt fall off on the opti side. thanks
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
30thZ286speed
Aug 3, 2002 04:54 AM
ferraricameron
Jul 29, 2002 07:46 PM
