Maf Screen
Old May 8, 2007 | 02:33 PM
LT1_King's Avatar
Maf Screen
i was needing to know how i would take off the screen on a 94Z A4. i have a cat delete with a strait pipe in place and i have a LM1. is this considered a free mod.
Old May 8, 2007 | 02:52 PM
96ZCamaro's Avatar
I wouldnt do it, it'll cause the readings to be off by a bit. You wouldnt gain enough power for it to be worth the risk. But if your just determined to do it take a box cutter to it but be carefull not to cut or even touch the wires in the middle of the sensor.
Old May 8, 2007 | 03:03 PM
arcticz28the383's Avatar
Can't he just take the snap ring out, so he doesn't have to damage the screen? I think theres a snap ring in there, not positive because I left my screen in there... and look at my setup.
Old May 8, 2007 | 03:05 PM
BUBBA's Avatar
Some have snap rings, others are not designed to be removed and would have to be cut. Having said that, I would not recommend removing the screen.JMHO
Old May 8, 2007 | 03:23 PM
Mikie's Avatar
Please dont nickel and dime mod the car. Just save your money for a mod that will benefit you
Old May 8, 2007 | 03:38 PM
2000GTP's Avatar
Agreed. I would leave the MAF alone. The ICM cooling mod and throttle body bypass mod are probably as far as I would go with the free mods.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
