stroker q's
Old May 13, 2007 | 12:30 PM
Bails098's Avatar
stroker q's
what is the best stroker kit for a nitrous motor 383, 396, 408 for a 1994 firebird
Old May 13, 2007 | 10:08 PM
ChevyTuffD.A.'s Avatar
Just shop around and get some info. Try to get a fully forged rotating assembly if your budget allows. Scat makes very good cranks and rods. JE and SRP are pretty good pistons from what I have read. I am sure some guys with strokers may be able to give you some better info. Good luck with the project.
Old May 14, 2007 | 06:29 AM
sssalah's Avatar
The most popular is the 383 lots of parts for it from several manufacturers. The larger strokers have no large power benefit if any, and it gets really difficult to get of the shelves parts for.
Get in touch with any of the supporting vendors here and they'll hook you up.
Old May 14, 2007 | 10:13 PM
Dan Parker '96's Avatar
My engine builder liked the Callies Compstar setup with Mahle pistons. He didn't like the supplied bearings (thought the clearance was a bit loose for his taste).
It's a nice matched package that should do well in any setup approaching 700hp.
EDIT: My engine builder did like that he had to do only minor clearancing to the block and that we could run a standard base circle cam without issue.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
