Cam Question.
Old May 13, 2007 | 11:08 PM
sandman63's Avatar
Cam Question.
Okay my opti is acting up an i need a new WP, so i decided why not throw the cam in there as well. Here's the problem, my old man thinks its a terrrible idea, he says that iam gunna throw a cam bearing or the thing wont run that well because the vavles have never been pushed that far before an what not. He also thinks that my MPG is gunna drop alot, is that true? either way i couldnt care less about the MPG.
I was thinking just a small cam, like a hotcam. Anyone experince this? or have a story to tell please shine in.
Old May 14, 2007 | 08:30 AM
Joe B's Avatar
The "very" mild GM Hot cam(or a similar spec'd cam) would work great in your situation and pick up a pretty good amount of power......Seriously Not even "one" of the concerns mentioned are real issues to worry about with that size and type of cam................Joe
Old May 14, 2007 | 05:04 PM
2000GTP's Avatar
I agree, go with a tame grind and you shouldn't have any problems.
Old May 14, 2007 | 07:06 PM
sandman63's Avatar
Thanks alot guys, yeah thats what i firgured. I had also asked my old shops teacher an he said the excact same thing.. i shouldnt have to worry about anything.
Old May 14, 2007 | 08:48 PM
seawolf06's Avatar
Don't forget to change the springs, too. Personally, I'm split by the hotcam. If you get it as a package deal it's nice because it comes with almost everything you need. However, it's also way too small for what I like, but that's a personal opinion.
I would like to just throw out the option of getting a slightly smaller cam with a spring kit that won't break your bank or hurt your drivability any more than the hotcam and that would be the Crane 227 baby cam.
CRN-104227 --- 210@ .479/ 224@ .518 (1.5RR)--- 112 LSA --- 2000-6000 RPM
Crane also makes a spring kit to go with it that would be perfect, and people seem to get better results with that one.
Old May 14, 2007 | 10:21 PM
sandman63's Avatar
Yeah i was gunna get the whole kit. What would you expect my rwhp be at with a hotcam, bbk shorty's and a EWP? along with the mods i already have( CAI an catback). BTW, its a A4.
Old May 14, 2007 | 10:47 PM
seawolf06's Avatar
Maybe 300 or so, depends on a lot of things.
Old May 15, 2007 | 09:43 AM
maybe2fast's Avatar
I would go with the 918 springs, they are designed for the heavier LT1 valves. The LT4 springs are designed for a little lighter LT4 valves.
I do have a set of never ran LT4 springs and hardware and a set of wide body comp cams 1.6 roller rockers. if you want to go with a CC503 or somthing like that.
email me if interested maybe2fast@gmail.com
btw CC503 is awesome!
Old May 15, 2007 | 10:48 PM
seawolf06's Avatar
Just a side note, the 918's were designed for the LIGHTER LS1 valves.
Also, don't put anything more than a hotcam in with LT4 springs. You'll really hurt something. Get the hotcam kit if you feel that 300 to the wheels will make you happy.
Old May 16, 2007 | 10:39 PM
sandman63's Avatar
Is that really it? 300? I was thinking more around 320 or something. Either way iam keeping my options open. I just liked that because it was a kit.
Old May 17, 2007 | 12:22 AM
seawolf06's Avatar
It depends on everything else you have, but if you'd be happy with 300 then you're almost sure to get there. If you're not happy unless you get 320, then it might be possible to get less. Numbers aren't everything, it's the drive that counts.
Old May 17, 2007 | 06:28 AM
sandman63's Avatar
Yeah i agree, but i just thought i would be a little higher than that. Even after a good dyno tune?
Old May 17, 2007 | 12:38 PM
seawolf06's Avatar
Not always, but sometimes. Google is your friend.
http://www.grandsportregistry.com/dynos/GS470dyno2.jpg
http://www.grandsportregistry.com/dyno.htm
http://www.dynoperformance.com/dyno_...&model=formula
sseeya
Apr 9, 2015 06:38 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
mongoose=
Mar 22, 2015 07:22 AM
aj2494
Mar 12, 2015 10:17 PM
alex5366
Feb 17, 2015 09:07 AM
