Car is overheating...
Old May 10, 2007 | 02:01 PM
The Captain's Avatar
Well now that the weather is warmer, I noticed my car overheats if I leave it sit and running, especially with the AC on. It is, however, running at normal operating temps as long as you keep the car moving. I havent checked anything yet, just wanting to get an idea of what to be looking for. I am thinking about flushing the coolant tonight, but other than that what should I be looking for?
Old May 10, 2007 | 02:26 PM
OBE1 95Z28's Avatar
proper functioning radiator cap, proper coolant/water ratio, proper operating fans, radiator not clogged internally or externally...
Old May 10, 2007 | 02:47 PM
camaroB4Cinterceptor's Avatar
usually if it is staying cool while driving, your fans arent working. i had the same problem in my 94. turned out it was a bad relay under the hood and i rigged up a toggle switch to turn the fans on manually.
Old May 10, 2007 | 03:00 PM
Ha, something electrical. Thats good for this guy! I can do electronics, but I suck at mechanical stuff. When do the fans turn on, or are they always on?
Old May 10, 2007 | 03:32 PM
96 Z 28's Avatar
Could also be that the Front Wind Dam is worn down.... In these cars that drives a lot of air into the radiator and if it's worn less air flow....
My car used to run hot in traffic, I had excellent luck with just a 160 deg Thermostat and that solved the issue.... Just really depends on how HOT and how often it gets HOT as to the best solution....
Old May 10, 2007 | 03:52 PM
Sholt_c33's Avatar
I thought that the wind dam was only effective while the vehicle was in motion? I don't think that would have any bearing on the car when it is stationary.
Old May 10, 2007 | 04:01 PM
96 Z 28's Avatar
TRUE Wasn't thinkin there
Old May 10, 2007 | 04:42 PM
JamaroZ's Avatar
Definitly need to check to see if your fans are coming on. Check fuses etc..
The fans should turn on around 190 or so I belive. When sitting does it get near the red?
When the car is moving the air hits the radiatior so the fans are not needed, thats normal.
Old May 10, 2007 | 04:58 PM
Yeah if I dont turn it off or get moving it will go past the red (found that out the hard way) Thankfully it didnt hurt anything. It probably just needs some coolant I would imagine.
Old May 10, 2007 | 08:20 PM
JamaroZ's Avatar
Have you checked you fuses, sounds like the fans are not coming on. If that the case adding some coolant will not fix that, your car will still overheat.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
