closed loop
Old May 8, 2007 | 08:32 PM
edunegan95's Avatar
closed loop
how many items can stop the computer from going in to closed loop?? i have an o2 sensor bad at the moment is it really that picky?!
Old May 8, 2007 | 08:34 PM
Red97LT1's Avatar
I had a bad Heated O2 sensor and mine wouldn't go into closed loop!
Old May 9, 2007 | 09:53 AM
OBE1 95Z28's Avatar
Here's a link to Injuneer's site explaining closed loop and much more:
http://members.aol.com/InjuneerZZ/ScanMast.htm
The short answer is:
-The O2 sensors have reached operating temperature and are beginning to cycle above and below 450mV
-The coolant temperature has reached the minimum set in the PCM. This seems to be in the range of 120 -140 degrees F.
-The "timer" has timed out - this seems to vary from 3 to 5 minutes, and seems to be longer in colder weather.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
tdigger9899
Sep 7, 2015 10:56 AM
