When does a 52MM TB becme a restriction?
Old May 13, 2007 | 08:46 AM
mdacton's Avatar
At what point does a 52 not flow enough air? And hopw do you figure it out?
Old May 13, 2007 | 10:20 AM
always faster's Avatar
I ve read from "injuneer" that a 52mm is max out at about 500hp(flywheel).
Old May 13, 2007 | 11:13 AM
When we had my 381 on the engine dyno, the 58mm TB was able to supply all the air the engine needed to make 500 flywheel HP at about 77% open. Opening the blades further did not increase air flow, or HP. If you work backwards from the 58mm throttle being open 77%, it would appear a 52mm TB at 100% would have supplied about the same amount of air.
Old May 13, 2007 | 11:17 AM
mdacton's Avatar
what about a Hi RPM smaller CID engine? would it be a restriction at higher RPMs on the smaller engine? with a higher piston speed it would consume more volume at some point.....
I was looking more towards a formula to find out.......I have some for carb. stuff but it seems to be way off.....
Old May 13, 2007 | 11:27 AM
The volume of air moved is a pretty much function of the HP being made. It isn't going to matter much whether its a large displacement making power at 6,000rpm or a small displacement making power at 8,000rpm. The volume of air required to burn the fuel that releases about 1/3 of its energy to make HP is pretty much "fixed". The plenum is there to decouple the throttle body from the intake runners.
Old May 13, 2007 | 12:33 PM
mdacton's Avatar
o.k that makes sense
Old May 14, 2007 | 07:13 PM
marshall93z's Avatar
I guess see if you are pulling vacuum at WOT.
Old May 14, 2007 | 07:29 PM
mdacton's Avatar
well I know that but this hasen't been put together yet......
Old May 14, 2007 | 07:37 PM
speed_demon24's Avatar
It's better to error on the side of too big with throttle body's, so if you haven't bought one yet I would just get a 58mm and never have to worry about it again. Look at the LSX community, they are running 90mm throttlebodies that make our 58's look like stock to compared to those. + the throttle response is alot better with a 58mm if that matters to you.
Old May 14, 2007 | 07:41 PM
mdacton's Avatar
I have one....got a used 52 cheap.....I know the 58 just tips in quicker like fred stated.........I'm sure it will be fine, I have made almost 400 with a stock one for the past 10 years
Old May 14, 2007 | 10:50 PM
F8T LT1's Avatar
Dual 58mm Throttle body should be approximately equal to a single 82mm throttle body. Having a 90mm throttle body should give you about 20% extra air flow. If that helps
Old May 14, 2007 | 11:46 PM
If you have a 52 I'de keep it unless you are worried about squeezing every last hp out of it, the only reason I sold my 52 for my 58 was that I ran out of boltons except an e-wp and I'm not going to run one of those, I didn't gain anything in the 1/4 with it though, then again i was only trapping 114 at the time so it probably wasn't a restriction back then.
Old May 15, 2007 | 12:01 PM
CamaroRacing12's Avatar
but would a 58mm make u loose power if u are no way near 500hp at the flywheel?... like could it be too big?
Old May 15, 2007 | 12:23 PM
Voridaeus's Avatar
No, only just a waste of money if you bought it as a mod and expected a power increase when you really didnt need it.
Old May 15, 2007 | 12:25 PM
say u were putting out 300rwhp and u have long term plans of 500rwhp would it help if u got a 58mm at 300rwhp?
