What do you guys think of this 355 LT1 Setup?
My block is at the machine shop, i already have a brand new LE2 setup, i was thinking of going this way with the block?
The kit is designed for you to build your own 355LT1 utilizing your stock GM 350 crank. The kit features premium forged Mahle pistons/rings/pins/locks, SCAT 4340 forged I-beam rods with 7/16" rod bolts.
Have your machine shop bore and plateau hone your stock block to 4.030, align hone the mains, square deck the block to 9.010", install cam bearings and oil galley and core plugs. Also have your balance shop balance your stock crank for the SCAT rods and Mahle power pack.
The -5cc flat top Mahle piston would give about 11.8:1 static compression ratio if using a 54cc chamber head with .029" B-body head gasket and piston in the hole 0.010". If the cylinder head combustion chamber is 58cc then static compression ratio would be 11.2:1 .
The 355 kit features the following parts.
Mahle piston "PowerPak" #SBC250030F05 (3.48 stroke, 6.000" rod, 4.030 bore)
The Mahle PowerPak features graphal coated forged flat top pistons, 1.5mm, 1.5mm, 3.0mm plasma moly file fit rings, F-1 style round wire locks and piston pins.
SCAT 6.000" 4340 forged I-beam rods with 7/16" cap screw style rod bolts #2ICR-6000-7/16
Lt1son
Dec 31, 2014 01:35 PM
