delteq timing question
Old May 15, 2007 | 02:20 AM
nickp's Avatar
I run nitrous at the track and I currently use a digital 6 msd box to retard the timing. I just built a new motor and was considering buying a delteq set up. How could I take out the proper amount of timing with this distributorless ignition? The way I understand it this system will not use my msd anymore. do i have to get lt1 edit or tuner cats to constantly change it every raceday? thanks for any advice.
Old May 15, 2007 | 06:16 AM
ZBLKHELLRZR's Avatar
To answer that question in short. Yes, you'll need LT1edit or some other system to control timing w/ the Delteq.
Old May 15, 2007 | 06:34 PM
hotrod18_69's Avatar
MSD DIS 4 Ignition box.. And your good to go..
Old May 15, 2007 | 10:45 PM
Dan Parker '96's Avatar
If you run a 150 or less shot then I really wouldn't worry about it. Just make sure you run an AFR of 12:1 or richer. You'll be safe.
Feffman
Oct 9, 2015 05:42 AM
capebuf
Jan 13, 2015 07:22 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Ari G
Dec 11, 2014 03:21 PM
