Huge Problem....motor mount mounting holes stripped
Old May 9, 2007 | 06:25 PM
eagleknight97's Avatar
Changing the motor mounts on my car and 2 of the 3 passenger side motor mount mounting holes are stripped. Its ridiculously tight in there and im going to try to remove the engine bracket so I can get some room to rotate the tap.
Old May 9, 2007 | 06:26 PM
mdacton's Avatar
in the block or the k-member?
Old May 9, 2007 | 07:58 PM
Dave1980's Avatar
Did you do it, or were they already stripped?
Old May 9, 2007 | 11:13 PM
K-member and it was probably my fault but luckily after my post freakout I went back out and only the first few turns were jacked up, running the bolt through that a few times and all was cured. Just took way more time than it should have...bout sums up my entire header and mount install
Old May 10, 2007 | 11:13 AM
Dave1980's Avatar
LOL, your learning a lot about your car is the way I look at it.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
alex5366
Jun 7, 2015 08:50 AM
geinsteder
May 6, 2015 06:02 AM
rjc1629
Jan 27, 2015 10:46 AM
