Delteq owner come inside(opti question)
Old May 11, 2007 | 09:58 AM
always faster's Avatar
Well since i ve found that i dont have any negative injector pulse: http://web.camaross.com/forums/showthread.php?t=518252 i tought about all my motor install...
The only thing that i ve modified is the opti itself.
When i install my DELTEQ it was suggested to take off the rotor of the opti for a safety issue.I did it and bought a DLT 4001 wich is a billet opti cover.
Here is the tricky part.When i put back the 2 bolts that hold the opti disc and was also holding the rotor before i took it off,i realize that the screw are to small in diameter to hold the disc...
So i just put a washer under each bolt.Tighten everything but the opti would not turn since the 2 small bolts are too long and touch the opti housing.
I ended up putting 2 washer under each bolt.Everything now clears perfectly.
For the DELTEQ owner:Have you done what i ve done or came up with a different idea?
Old May 11, 2007 | 03:15 PM
Ultra_Dog's Avatar
I just installed delteq and threw away the plug wires from the opti. Everything inside the OPTI is still spinning around. Why open a can-o-worms?
Old May 11, 2007 | 03:35 PM
sweetride45's Avatar
I heard about the rotor exploding/etc. at high rpm, but I didn't take it out when I put the Delteq. I figure, I'm not spinning to 7k+, so I could care less...I also didn't change the Opti cover, b/c you can't see the damn thing anyway...works perfect (new ac delco opti w/ delteq)
rjc1629
Jan 27, 2015 10:46 AM
capebuf
Jan 13, 2015 07:22 PM
Injuneer
Dec 15, 2014 09:36 AM
Ari G
Dec 11, 2014 03:21 PM
